Having a problem with a new boat I just purchased. 200 hours. Service records (but not at a nautique dealer).
trans functions as it should when cold. After it gets hot from boarding, it takes throttle to engage the transmission (but not in reverse).
Normally it engages as soon as it’s taken out of neutral, which is exactly what it does when it’s “cooler” or cold. It’s slipping while hot.
what could be wrong? Trans was just serviced. If anything it could have a little too much fluid.
would incorrect fluid cause this?
I checked linkage and even adjusted it a little with no luck. But the fact it only happens when hot says it’s not the linkage and I’m worried...
