Which boat do you have again? On a direct-drive, it isn't bad at all.
It’s a 2004 210 SANTE... it’s only sticking when moving in and out of gear and the handle is pretty loose. Was thinking of doing the cable (because it’s the hardest) and if that doesn’t solve the problem then it’s the shifter. Did the throttle cable when it was torn apart but stupidly didn’t do the trans cable.
