HELP!! Engine no start, throws check light with no cranking (07 model 206 with ZR6)
  • James
    • May 2007
    • 151
    • Indian Wells, CA
    #31
    Just a thought... have you checked the battery cables. I had a starting issue with my 2006 216 several years ago. There was enough power that all the accessories, bulge pump lights etc. worked but not enough power to turn over the engine. I thought it was a failing battery. Not so. It was the original positive battery. The multi strand copper cable actually became corroded and loose inside the battery post clamp causing a bad connection. I had a new cable made. Problem solved. Just a thought
    • Donbayers
      • Aug 2019
      • 29
      • Las Vegas
      #32
      All good suggestions. I had just installed a new batt and completely cleaned the connections. I also removed all connections at the started and cleaned them. I'll now go back and work the ground side. something crazy but simple is happening to me........oh the humanity
      • shag
        • 2217
        Was the boat used in Salt? None the less, it sounds like new battery cables would not hurt, for the above reasons. Sometimes you can not tell from looking but the stranded wire inside becomes corroded and loses the ability to carry amps.
        • Plum Nauti
          • Mar 2012
          • 13
          • Noblesville, IN
          • 1999 Ski Nautique
          #34
          Have you found a solution for your problem ? I read where you checked the neutral safety switch by touching the wires together. Did you verify that 12vdc
          was present at the neutral safety switch ?
          • Donbayers
            • Aug 2019
            • 29
            • Las Vegas
            #35
            OK, IT'S RUNNING!!!!! BUT STILL BIZARRE SITUATION
            So I got back the PME box and the key pad panel from Nautique Parts (he testing them at NO CHARGE, nothing wrong) and connected them.
            I then removed and cleaned the main ground connections (one on side of block and one at the back). I tried the engine and NOTHING....
            So at that point I think to myself I'll just jump the starter directly and run it BUT then I thought about making sure I could turn it off!!!!
            I started looking around thinking about how I could cut the motor if the main stop button didn't work. All of the sudden I notice a fuse box on top of the engine with a pic that says "starter relay". So I open it up....looks fine in there and I pull out the fuse, looks fine. I cycle it in and out a few times and put the cover back on (see pic).
            I then go over to the main power switch and flip it down to bilge and then "all power on" (keep in mind I've done that 50 times in all this)
            Enter the engine start code, hit the start button and the **** thing turns over and starts much to my amazement!!!
            So in the end I really don't have a smoking gun but the only thing I touched after the last 'non-start' was that fuse starter relay and then that toggle switch...
            Crazy, right.
            Click image for larger version  Name:	IMG_8340.jpeg Views:	0 Size:	34.1 KB ID:	607861
            • Donbayers
              • Aug 2019
              • 29
              • Las Vegas
              #36
              Second pic
              • James
                • May 2007
                • 151
                • Indian Wells, CA
                #37
                In your case “crazy” is good
                • perry386
                  • Jun 2012
                  • 560
                  • gadsden AL
                  • Super Air nautique 236
                  #38
                  There’s a fuse box right beside the fuel cell on the ZR6 motor. Check the fuses same thing happen to mine and that was the problem
                  • Jrod77
                    • May 2022
                    • 15
                    • New Braunfels, TX
                    • 2007 Super Air Nautique 220 TE
                    #39
                    Did this ever get resolved?
                    • Jrod77
                      • May 2022
                      • 15
                      • New Braunfels, TX
                      #40
                      Did you have any luck with figuring this out? I know this is 4 years old, but I might be having the same problem.
                      • Jrod77
                        • May 2022
                        • 15
                        • New Braunfels, TX
                        #41
                        I think I might have the same issue, but I do not have that box in my engine compartment. I have a 2007 220 TE with the excalibur 330. Where would my box be located?
                        • Jrod77
                          • May 2022
                          • 15
                          • New Braunfels, TX
                          #42
                          Figured it out. I went to the breaker box. It was under the shroud covering the engine. I took out each relay and fuse. Sprayed WD40 in each seat and then resat every fuse. Boat fired right up. No issues. Great thread
                          • Donbayers
                            • Aug 2019
                            • 29
                            • Las Vegas
                            #43
                            Hey! Fantastic news that this helped. All the best
                            • Jrod77
                              • May 2022
                              • 15
                              • New Braunfels, TX
                              #44
                              Yeah, looks like we have the same boat, so I'm glad someone else had this same issue. Sucks that you had to go through all the actual labor to get this done, but in the end, we got our boats working again. Thanks again for all the details and pictures.
                              • Jrod77
                                • May 2022
                                • 15
                                • New Braunfels, TX
                                #45
                                I also went and ordered backup parts for all fuses in that box as well as another magnetic telescoping tool so that I had (2) on hand. We all know it never hurts to have (2) of everything.
