Hi gang. Hope the collective experience here can help.
Bottom line: enter start code (everything powers up on dash), hit start button, I hear fuel pump buzz for about 5 seconds then stop, then check engine light comes on. pushing start button again nothing happens i.e. engine never cranks.
Details:
Got boat out of winter slumber.
Put brand new battery in it.
connected water and it started right up
warmed up engine to change oil and filter
shut off, drained oil, changed filter. etc.
Then upon restart the above happened
Engine has 700 hrs on it.
Something is causing a fault code to trigger that then prevents cranking of the engine! Any ideas what this could be and how I can go about testing things?
I read here some posts about fuel pump relay... but if relay was not working then the pump wouldn't turn on in the first place...? Under normal operating conditions I don't recall hearing or waiting on the fuel pump before hitting the start button.
Please know that the boat is new to me just since Sept 2019 and I've only had it out once.
Thank you for any help
PS. I have all the owners manuals and documents for the boat including full service history (it was a one-owner and only serviced at the dealer) but these references don't help much.
Details:
