Originally posted by Mahnal
View Post
You need to run your hand all the way down the entire length of the oil drain hose to where it comes off the oil pain to make sure it isn't kinked.
As someone mentioned above, the fitting on the oil pan directs the drain hose toward the stern of the boat, but the engine installers pull the hose toward the front of the engine where it is clipped on a lifting ring. This will often cause a kink in the hose.
Check the entire length of the hose and let us know what you find.
