Rough start and Idles - Fuel coming out Carb Vents
  • endgame
    • Sep 2019
    • 3
    • CT
    • 1197 Ski Nautique 176
    Hi everyone,
    So I just bought a 97 176, and was having trouble getting it started. When I tested it out, it hard started but then ran fine after that on the lake, no idle issues.
    I went to winterize it and could not get it started. Finally after speaking to the previus own he let me know I could put in neutral and open the throttle. That worked.
    The problem is , I can't get it to idle without feathering the throttle about half way down, anymore towards 12 high and the rpms go down below 500 and the engine stalls.
    I also noticed that fuel is dumping into the carb from the rear carb j vent tube.(this happens immediate when I try to start the engine) I thought this was normal until I researched it and I can't find any info on why it is happening.
    What would be causing this and is this the reason my engine won't idle properly?
    Thanks for any help (I'm not a mechanic so please forgive my ignorance)
