Have two PCM 5.8 Ford Windsor’s in my boat and I have been struggling to find the total advance timing and what rpm its at. They are 1999’s and 260hp models with prestolite electronic distributors. Any help would be appreciated .
How did you determine that? I have always wondered with the high-speed advance should be on these engines. Is this just from setting the idle advance and checking it at high-speed to see what you've got?Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Yes
here is a base line that was posted on CCF
Edit : may be different just noticed the OP has an electronic distributor but should be similarSpeaking of numbers, for whoever cares, here's what I came up with for the PCM heavy spring and a Hillman #119 installed in a clip down cap distributor.
RPM advance
500 0 plus initial
1000 4 plus initial
1500 12 plus initial
2000 16 plus initial
2500 18 plus initial
3000 22 plus initial
3500 24 plus initial
4000 26 plus initial won't go any higher because of the slot length in the advance plate (also referred to as the stop plate at times) limiting the advance.
Now these were with my tach which may read different than your tach and my eyeballs which aren't your eyeballs but they give you an idea of the timing curve with the springs mentioned above.
Some people may like it, some may not, but I think it's pretty good keeping in mind that with the heavy spring you don't reach full advance till about 4000 rpm as it originally came from the factory.
The engine runs good with this setupLast edited by gun-driver; 08-15-2019, 11:15 AM.
