Hola, got an issue that has been developing slowly over the last couple weeks. Started with engine dying after 1.5-2 hours of use. Then took 10-15 minutes before it would start again. Did turn over but did not start until then. Something getting hot, needing to cool down..?
Happened 2 or 3 times, then also died after only a couple minutes of use. Plus getting harder/taking longer before it would start again.
Now, been trying to figure it out for several days, some days it won't start at all. Other days it will start once, run for 15 minutes or so, then die and won't start again. If it runs it runs pretty good. Not perfect, especially when idling you feel/hear rpm's change a little bit, but nothing terrible.
Changed the fuel filter inside the FCC.
Got a spark, and got fuel going into the rails.
Changed ECM with one from another GT40 but didn't change anything.
Spark plugs were pretty grey but seem OK. Going to try to find the right ones though and change 'em out (not as easy as it sounds where I am).
What's driving me mad is that occasionally it does fire up, but 99 out of 100 attempts it does not.
I read about starter solenoids, could it cause this behaviour? Where do I find it and how can you check if it's working OK.
Other recommendations, tips, ideas...?!
Thanks in advance!
Thanks in advance!
