07 SANTE 220 with stock trailer. Trailer states it has buddy bearing system that appears to be similar to a vault system. How ever on the trailer I have dust caps on the hubs. Possible previous owner removed them?
Tags: None
I'm not familiar with the Vault system, but mine has the Bearing Buddy system. You pry the little dust cap off to access the grease fitting. As far as I can tell it is totally worthless. I had them a part to work on brakes recently. It would take more than a tube of grease to reach the inner bearing. I could see each layer of grease a previous owner had pumped in through the fitting and it hardly even reached the outer bearing.
