Announcement
No announcement yet.
1998 SS caution light staying on past 1200 RPMS.
  • funkster
    started a topic 1998 SS caution light staying on past 1200 RPMS.
    I finally got to take the boat out for the maiden voyage. Everything else seemed fine but the caution light stayed on passed 1200 RPMS. I checked the engine oil and it was full. I then checked the V-drive oil and it didn’t register on the dipstick. Here are my questions:
    1. Would low V-drive oil cause the caution light to stay on?
    2. What is the proper way to check the v-drive oil? I tried to check it with the motor running at normal operating temp and the oil didn’t register. I then shut off the motor and checked it again and the oil still wasn’t registering.
    3. What is the recommended oil and volume?
    One other thing I feel is note worthy is I changed out all the gauges (including the RPM gauge) and installed PP stargazer. Could this part of the problem? Any help would be greatly appreciated.
  • funkster
    replied
    Jeff, thank you very much! This info with the diagrams are very helpful.
    Also, thank you for the info on the PP low voltage beep. I ran a new ground, installed a ground buss bar and hooked up the stargazer ground directly to the buss bar. No more low voltage beep and running a solid 13 amps. You the man!
    Leave a comment:
    replied
    That light has nothing to do with engine oil. It is strictly for the V-Drive.
    From the 1998 Super Sport Owner's Manual:
    Leave a comment:
