Anybody know the correct impellers to get for the ballast pumps and water intake pump on a 2019 210? I saw a green and a pink one online but I wasn’t sure which one was the correct part. Also, has anyone upgraded the stock ballast pumps to a larger pump to fill the ballast quicker? Is it just one ballast pump that flows both ways to empty and fill the ballast or is there a second pump plumbed in to empty the ballast?
The pumps are reversible so there is only one pump per tank to fill and drain the tank.Originally posted by AKJerrod View PostAnybody know the correct impellers to get for the ballast pumps and water intake pump on a 2019 210? I saw a green and a pink one online but I wasn’t sure which one was the correct part. Also, has anyone upgraded the stock ballast pumps to a larger pump to fill the ballast quicker? Is it just one ballast pump that flows both ways to empty and fill the ballast or is there a second pump plumbed in to empty the ballast?2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
For the newer Nautiques such as your 2019 210 get the pink impeller not the green ones. They cost a bit more but they are suppose to last longer. I keep a complete set of pink impellers in my boat inventory at all times.Originally posted by AKJerrod View PostAnybody know the correct impellers to get for the ballast pumps and water intake pump on a 2019 210? I saw a green and a pink one online but I wasn’t sure which one was the correct part. Also, has anyone upgraded the stock ballast pumps to a larger pump to fill the ballast quicker? Is it just one ballast pump that flows both ways to empty and fill the ballast or is there a second pump plumbed in to empty the ballast?
Is it the same impeller for water intake pump as the ballast pumps?Originally posted by GMLIII View Post
No they are different impellers.2009 Super Air Nautique 210 TE
1989 Sport Nautique
