Winterize in an insulated storage?
  • LindMark
    • Jul 2018
    • 34
    • Fort Worth, Texas
    • 2012 SAN 210TE
    In Texas. Boat is kept in an insulated hangar. I've never seen the inside temp lower than about 40. Would you still drain and winterize in this situation? Is there any benefit? Anything else to consider for winter storage besides freezing issues? Thanks.
  • Calisdad
    • Jul 2017
    • 20
    • Dallas, Oregon
    • 98 Ski Nautique
    I have a similar situation here in Oregon. Boats in an insulated garage and even when the temps are below freezing and even single digits it’s still 40 in the garage. I still change the oil, fill the cooling system with antifreeze to help prevent corrosion, fog the cylinders and run stabil with non ethanol premium fuel. It’s cheap insurance.
    • swc5150
      • 2240
      • Eau Claire, WI
      • MasterCraft Prostar
      The old saying I grew up with was 24 degrees for 24 hours to crack a block. Does that ever happen in TX? If you want peace of mind, drain the block and manifolds. I don't know about PCM these days, but I don't fog my Ilmor per the manual, due to the cat sensors.
      '08 196LE (previous)
      '07 196LE (previous)
      2 - '06 196SE's (previous)
      • 03SANTE
        • Sep 2018
        • 166
        • PA
        • 2003 SANTE
        Would be wise to drain everything merely to crack all of the plugs open. Wouldn't want them seizing up in case the boat needs a real winterization in the future.
        • scottb7
          • Aug 2011
          • 2198
          • Carson City, Nevada
          No, I wouldn't winterize, unless like was said above it is going to get below 24 for 24.
          If I had easy access, I would go over and without starting the motor turn if over once a month. But that's about it.
          • Nautiquehunter
            • Jun 2008
            • 2099
            I live in north Georgia it pretty much stays above freezing all winter long. That being said it does go below freezing usually for short periods like overnight. I currently have 5 boats I keep inside a 40x60 unheated pole barn . I have never seen the temp below freezing inside the barn. I still winterize all my boats the same as when I lived up north.The only difference is I only mix the antifreeze down to 0 F instead of -30 up north. There is no doubt I could get away with just draining or doing nothing but for the cost of materials and the 15 minutes it takes to drain and fill why take the chance? I guess you just gotta ask yourself '' Do you feel lucky'' ?
            • greggmck
              • Oct 2014
              • 796
              • Bellevue WA
              • 2023 Paragon G23
              What boat/engine do you have? The new ones have blue plugs. They literally take 15 minutes to winterize. I wouldn't hesitate to do it...
              Sent from my SM-G965U using Tapatalk
              • LindMark
                • Jul 2018
                • 34
                • Fort Worth, Texas
                • 2012 SAN 210TE
                2012 SAN 210 with pcm343ex
