Gas
  • Sjimbert
    • Dec 2018
    • 13
    • Switzerland
    • Super sport 1998
    Gas
    Gas consumption
    Hi, I am looking at buying a super sport 1998. Could anyone help me figure out what the gas consumption would be on average? We would like to do some wakesurfing mainly. Thanks a lot!
  • GMLIII
    • May 2013
    • 2821
    A lot. If you are worried about gas consumption you need to explore other entertaining options other than boating and water sports in general
    • Sjimbert
      • Dec 2018
      • 13
      • Switzerland
      • Super sport 1998
      Thanks for that. I already have a bayliner and spend quite a lot on gas. It’s not about no wanting to spend on it but have a general idea if it’s going to be way more or not basically. Would you know if it’s 10l/h or more 20?
      • kylem03
        • Jan 2009
        • 178
        • Wisconsin
        • 1983 Ski Nautique 2001 1994 Sport Nautique 1995 Super Sport Nautique 2007 Nautique 236
        Plan on 6 gallons an hour and that ought to put u in the ballpark for surfing, cruising, and wakeboading with ballast.
        Kyle
        • siderider
          • Nov 2010
          • 17
          • orlando
          • 2007 236 2001 SAN210 1983 2001SN
          I previously owned a Super Sport 210 with the 5.8 Ford GT40 and would average around 3 to 4 gallons an hr surfing and 6 to 7 gallons per hr at wakeboard speeds using Acme 1464 prop and 1500 to 2000 lbs ballast. The 3800-4000 rpms at wake speed with that prop almost doubled consumption over surf speeds.
          • Sjimbert
            • Dec 2018
            • 13
            • Switzerland
            • Super sport 1998
            Thanks for that. Super helpful. What year was your boat?
            • siderider
              • Nov 2010
              • 17
              • orlando
              2001 Only negative I could give is a little short on space with more than four people and gear when all the space is used for ballast. Great boats for sure. Good luck
              • Sjimbert
                • Dec 2018
                • 13
                • Switzerland
                • Super sport 1998
                What do you exactly use as ballast system? How do you place them on the boat? Don’t you put them on the space next to the engine?
                • kylem03
                  • Jan 2009
                  • 178
                  • Wisconsin
                  Yes, 750# bags on either side of the engine, 500# in the ski locker, and a few hundred under the bow.
                  Kyle
                  • Sjimbert
                    • Dec 2018
                    • 13
                    • Switzerland
                    • Super sport 1998
                    Would any of you could share videos or picture of what the wave look like with your system? Would be amazing! I bought the boat - winter will be so long!!!
                    • SoCal G-Man
                      • Apr 2016
                      • 329
                      • Westlake Village
                      • 2019 Super Air Nautique G23
                      IME, moving from a runabout (like a Bayliner) to a wake boat increases fuel consumption simply due to the fun factor and the amount of time you are pulling. Add ballast and consumption increases more. Add surfing, and consumption increases more.
