on my 2006 196 Limited, where are the air and water temp sensors?
Tags: None
Water temp sensor on my 03 is right above the through-hull fitting and seacock for the engine cooling water.
I never found my Air sensor, but it must be stashed somewhere deep because it always reads cooler than actual temp when we are out on the water.
Sent from my SM-J320V using Tapatalk
