2018 GS20 Sun Pad Latch hold down rubber insert
  • JJR
    • Feb 2018
    • 7
    • VA
    My sun pads to the left and right of the engine cover no longer stay down. The rubber insert in the latch hold needs to be replaced after just one month of use. Is there a place on line that I can purchase replacement inserts?
  • GMLIII
    • May 2013
    • 2820
    www.nautiqueparts.com
    But before you purchase them this should be covered under warranty. I would check with your dealer first
    • ScooterMcgavin
      • 1551
      • 2014 SAN 210 TE
      Contact your dealer, that's covered under warranty. Nautique is in the process of, or has already made them different to address this issue.
      1989 Sport Nautique
      • kylant
        • May 2010
        • 549
        • Lake Tahoe
        i noticed the '18 boats have a metal surround.
        what is the "new" configuration?
        I am surprised there is no latch to hold them down
        • JJR
          • Feb 2018
          • 7
          • VA
          I cannot find this part on the www.nautiqueparts.com web site.
          • GMLIII
            • May 2013
            • 2820
            [QUOTE=JJR;n565030]I cannot find this part on the www.nautiqueparts.com web site.
            [/QUOTE
            As other said I would start with your dealer first because it would be a warranty item but if you want to contact Nautique Parts call "Townsend". Sometimes some of the newer parts are not listed on their website therefore you wil need to run your part in question by Townsend and he will give you the part number to order.
