Wakemakers ExactFit 600lb SAN210 Upgrade - Engine Divider Fix
  • tachyon
    • Mar 2012
    • 96
    • Stillwater, MN
    • 2001 Super Air Nautique
    I ordered all new support channels, it was just under $100 fo all four shipped. I’m going to go a different route for ballast.
    • tachyon
      • Mar 2012
      • 96
      • Stillwater, MN
      FYI for everyone dealing with failed divider supports: the new parts that I received from Nautique have reinforcement (est. 1” wide by 1/4” thick) welded to the inside of the channel. This should make a huge improvement over the original parts that were on my 2014 SAN.
      I’m really happy to see that Nautique made the design improvement.
      See you in Spring!
      • Vic
        • Jul 2020
        • 9
        • British Columbia
        • 2016 Super Air Nautique 210
        Hi, I know this is an old post...did you end up finding a permanent solution? I was just going to try the plywood, but you are saying it still bent everything ?
