Just wanted to educate myself as the boat goes to the dealer on Thursday. Boat is 2016 G23 with H6 and 305 hours.
Last week the boat wouldn't start one time. I jiggled the throttle, check the safety lanyard. Screen is on, start button just does nothing. It turns on the screen, but no click, doesn't turn over. It is just as if the boat is still in gear. I turn off the batteries, jiggle throttle again and start looking around wondering who will tow my 6 figure boat back to the dock. Then it started. Being a fool, I just hoped it was a computer glitch and let it go.
2 days ago was out and boat was running great and the same thing happened. This time lasted for longer and I was seriously about to start waving my long arms for help and got it to start after about 15 minutes. I didn't shut it off until we were on the trailer. Voltage reads fine, boat is running great otherwise. Cycling the batteries did not fix it. I think jiggling the throttle left and right (instead of forward and back) got it to start.
I get back to the garage and find that if I move the throttle just right, I can reproduce the no starting situation. It is definitely in neutral and clicks perfectly back into place, but with a gentle easing into neutral from reverse, it wouldn't start.
So something is definitely wrong with the throttle assembly. My dealer's tech mentioned some adjustment on the throttle that might be out, but I thought it was all by wire, and figured the whole throttle assembly has to be replaced since there seems to be a throttle position sensor issue. Unfortunately, I am a little sketched out with a big trip coming up to Lake Powell where getting stranded may literally be a safety issue. Maybe my tech was thinking about a 2014 which still had throttle by cable? I will make sure he teaches me how to adjust it so I can at least get back to the houseboat if I get stranded. The intermittent nature of the issue also makes it a little hard to diagnose, and I will for sure be frustrated if I get it in the shop and he can't reproduce it.
Is there anyway to safely 'hotwire' a boat with this issue?
On a side note, the button that allows you to rev the motor without putting it in gear has not worked for a long time...I keep forgetting to tell them about it. Doubt it is related, but wonder if anyone has an idea how to troubleshoot that.
