2000 SN/OB Horn issue won't turn off!
  • MNkneeboarder
    • 6
    • Chanhassen MN
    • 2000 SN
    Boat fresh off winterization, I hooked the battery up and the horn would not turn off. I was able to start the boat with the horn blaring. I unplugged the wire that leads to the horn. I hooked the battery back up. Then I tried turning the boat back on then kicked the blower breaker. I am totally at a loss? Any ideas out there.
  • Jsimmo97
    • Jun 2021
    • 16
    • Austin, Tx
    • 2000 SAN
    Curious if you ever solved this one and how?
    • MNkneeboarder
      • 6
      • Chanhassen MN
      • 2000 SN
      No, I think the only solution is to replace the ECM. I have unhooked the horn for now. Someday I will have the ECM replaced.
      • charlesml3
        • Jan 2008
        • 2487
        • Lake Gaston, NC
        • 2022 G23
        What? No. The ECM has nothing to do with the horn. You are talking about that horrible sounding horn on the starboard bow, right? Most likely it's a bad switch.
        -Charles
