2007 Super Air 220 with 500 hours.. knock sensor comes on randomly and then will go away once I slow it down, I can speed back up and it does not usually light up again. I know bad gas could cause that but Ive got some new fuel in it now and had to of ran out all the residual fuel. My prop needs to be replaced because it has a bad vibration at moderate RPM and it made me wonder if the sensor can pick up that shudder and make it go off?
Either way I've got a new prop and knock sensor on the way. I don't have the manual so I'd like to know where exactly the knock sensor is on the block?
Any insight helps. thanks!
