No signal to forward
  • SierraWave
    • Sep 2016
    • 59
    • Imperial Lakes and Dollar Point
    • 2015 200 2016 G23
    I have a 15 200 with the electronic shift trans. It does not go into gear when the throttle is moved forward only the revs go up. I swapped the plugs on the trans and put the throttle in reverse and the boat went forward. The problem is intermittent. Any one else have this problem?
  • distinguishedmotorsports
    • Aug 2016
    • 489
    • Austin, TX
    warranty, too new not too, IMO
    haven't heard of that happening either, granted, there are not a ton of 200s on the board either.
    • Nautiquehunter
      • Jun 2008
      • 2099
      Still under warranty?
      • AdamJBarn
        • Feb 2016
        • 51
        • Fishers, IN
        • 2002 Super Air Nautique 210
        Is the 200 not under warranty?
        • Schafer
          • Apr 2025
          • 3
          • Lacombe, Alberta
          • 2016 200 6.2 L
          im experiencing this exact thing.
          did you get it fixed? Throttle base assembly?
          • jpwhit
            • Aug 2016
            • 656
            • Cary, NC
            These symptoms are typically caused by a failing Throttle Base Assembly. They are terribly unreliable. I know of folks that are on their third one.....
            • Schafer
              • Apr 2025
              • 3
              • Lacombe, Alberta
              • 2016 200 6.2 L
              Quote removed by Admin for not following the Guidelines for Quoting Previous Posts in a Thread.
              This will now be my 3rd one too.
              anyone had any luck trying to repair the base assembly?
              • lilet
                • Apr 2011
                • 40
                • greece
                • Nautique 200 CB Nautique 196
                im experiencing the same thing. have you sorted it? i used a working throttle from a gs20 and still doesnt work. did you check the two plugs that go on the transmission? one of them doesnt have voltage on mine but dont know where the problem is.
