2007 Ski Nautique starter spins, won't engage flywheel
  • DocSki
    • Feb 2018
    • 17
    • Long Beach, CA
    • 2007 Ski Nautique
    After I enter my code on the keypad and press Start, the starter spins but doesn't engage the flywheel (no engine turnover). I don't hear a "click," but I'm not a mechanic. There is no grinding. I have charged the battery (2.5 years old), cleaned all contacts, and banged the starter with a hammer (through a 2x4 piece of wood). Boat has 250 hours. Rainwater filled the bilge during torrential rains and rose up to the starter one year ago. I'm guessing this is a solenoid problem, but I don't have a volt meter to test it myself (and I'm not sure what to test, anyway). Mechanic I spoke to recommended pulling the starter and sending it for testing, possibly have it rebuilt. I think I could remove it myself (I replaced a starter on a car...once), but it's tight quarters and I'm a little worried about screwing up the wiring. Also, I've read about relays and secondary solenoids, but I don't know if those are relevant to my boat. Any comments or suggestions would be appreciated. Thank you!
  • ScooterMcgavin
    • 1542
    • 2014 SAN 210 TE
    There isn't much wiring to screw up, yeah it's Tight quarters but can certainly be done. If you've changed one on a car it's really not that different. I'd recommend pulling it and either do a bench test yourself with a 12v battery And a set of jumper cables, or take it to local auto parts store for bench test. More than likely probably just needs to be replaced.
    1989 Sport Nautique
    • DW SD
      • Mar 2015
      • 416
      • San Diego county
      • 2001 SAN 210
      Likely just replace the bendix. That’s what pushes out the gear to engage with flywheel.
