I don't believe the GM 350 is common in these boats and I'm struggling to find info for service. I found the service manual here on PN, but it doesn't give much info on service. It's more of a repair manual. I have a few issues with the boat I'd like to sort as well as a full service before next season. Here are my Q's:
1. I have a heated garage, must I winterize the boat?
2. The throttle is stiff, have to hit it with your palm stiff while underway to adjust speeds. It feels fine with the engine off, I've disconnected the cables and they all move with no resistance. Is the throttle assembly a wear item on these boats?
3. The temp gauge stays relatively low while operating. My first thought is a thermostat stuck open, but again I'm not sure where it is, and what gaskets are required. Thoughts?
4. The steering cable has been replace with a factory part. Again, not in motion it turns freely, while underway it's two hands or bust to get this tank to turn. Is there a rudder bearing on these old boats that can be greased?
5. It looks like the raw water impeller is on the front of the crankshaft? Can anyone verify?
Just trying to get my ducks in a row before ordering parts and digging into this thing. Thanks in advance.
