Winterize Ballast or Not?
  • Evening Shade
    • Apr 2015
    • 1295
    I'm curious, do most people winterize their ballast or not? If you do winterize it what is the easiest way to do it.
    I've never winterized by ballast in any of the wake boats I've owned and never had any issues, but it seems like several people on PN winterize their ballast.
    Granted it doesn't get terribly cold here in GA, but we do see freezing temps several times in the winter.
  • Nautiquehunter
    • Jun 2008
    • 2099
    I am at Lake Lanier GA same temp as you. I am from the north so my winterizing is a bit overkill for GA. I have 5 boats so winterizing them is a project . I use 30 % green antifreeze giving protection down to zero. I like the green because it has rust preventers in it and you can add more antifreeze to the mix to get lower freeze point. I use 1 gal of RV antifreeze in each ballast tank. I use the ballast pump to add the antifreeze just remove the suction hose and put a different hose from the pump to the gal of antifreeze. It will suck it dry in seconds.
    • NautiqueOasis
      • Oct 2005
      • 142
      • Dayton, OH
      • '13 200V Sport; '05 SV211; '97, '90 , '85 & '79 Sk
      I use a Fake-a-Lake to winterize my ballast tanks; place the fake-a-lake over the intake under the boat; run a hose to a bilge pump in a bucket full of RV antifreeze; plug the pump into my 12v receptacle in the boat; fill tank for a few seconds to put maybe a 1/2 gal in each tank; then hit empty tank to run antifreeze completely thru pump. My boat is stored on the KY/TN border near my houseboat dock.
      '13 200V Sport Nautique
      '05 SV211 Nautique
      '97 Ski Nautique
      '90 Ski Nautique
      '85 Ski Nautique
      '79 Ski Nautique
      • Infinity
        • Sep 2017
        • 730
        • Lake Norman - Denver, NC
        • 2014 SV244 w/ ZR409
        I know some of you guys have hard tanks....I remove my bags and just pour about a 1/2 gallon of anti-freeze into ballast hose leading to pump and bump the "empty" for a few seconds to suck anti-freeze thru pump (since my pumps are reversible)
        • max 1.6
          • Oct 2014
          • 287
          • Canada
          • 2009 Nautique 230
          And just make sure you have antifreeze in the hoses where it can accumulate water.... Making sure you won't have residual water anywhere
          • DocPhil
            • Jan 2016
            • 480
            • Midwest
            • 2016 G23; yamaha superjet
            I have a 2014 G21 and I confirmed this with 2 local Nautique dealers in MICHIGAN. It gets cold as balls up here.
            Both said run the tanks on empty for a bit then pull ballast impellers. Done. No need to add AF.
            • scottb7
              • Aug 2011
              • 2198
              • Carson City, Nevada
              Thanks for checking, with dealers. since the manual is clearly wrong at least for g boats, due to having anti siphon valves not allowing pour in of antifreeze.
              Sent from my SAMSUNG-SM-G925A using Tapatalk
              • hondaprlud
                • Jul 2008
                • 568
                • OH-IO
                My dealer also runs them dry. No antifreeze.
                19 SANTE 210
                08 SANTE 210 ZR6
                08 SANTE 230 ZR6
                88 Baja Ski Sport- First boat
                • homer12
                  • Feb 2016
                  • 584
                  • Indianapolis, IN
                  • 2004 SV211 TE
                  How about those with aerator pumps? That's what I have.
