I have a '97 Super Sport. Should have 2 bilge pumps, but only has one in front of the rudder. Manual says it should engage every 5 minutes, checking if there's water to be pumped out. Mine pumps every 2 seconds, so I can't leave it on all the time or it'll discharge the battery. I'm keeping my boat moored, so it'd be very convenient to keep it on all the time! Is there a way to adjust the timing, of when it engages? Or do I have to change out the pump?
Also, the 2nd pump should be under the shaft I think. The one that I have is this type Rule pump. I wonder though if that same one would fit under the shaft? Or is there a smaller one?
Thanks for any and all info!
