Hit a log last weekend. Bent a shaft and prop. Got everything apart this weekend. Current plant is to replace the shaft with A.R.E and install PSS shaft seal. Thrust bearings look fine. Engine alignment needs to be checked, but doesn't appear to be too far off.
Here's where I overthunk... I'm running 2500lbs of ballast when surfing. I had/have a 14x16 OJ prop (think stock is 14x18). I'm at sea level, btw. The prop was great for wakeboarding and okay for surfing. By okay, I mean fine at surf speed, but with full ballast and 4/5 people in the boat, I could not get on plane. Would have to drain at least a third to get to a manageable load. Felt like I was killing my drivetrain. I'm not sure if that's typical from experience of others.
Anyway, I sent my prop back to get repaired and OJ is telling me it is "bent to the hub" and cannot be repaired. they offered $100 towards purchase of a replacement, but don't have any other sizes for my boat. Looking at $372 (with discount) for a new 14x16 from them.
Option 1: get replacement prop same size at discount
Option 2: take the loss from OJ and go try new acme 1578
Option 3: try to get damaged prop back and get another opinion from another shop?
Option 4: TBD???
Any advice or things to consider from others with experience would help me make a decision.
Rusty
Option 4: TBD???
Rusty
