I sure hope someone can help me before I go crazy messing with this boat it's a 2004 air nautique limited 210 with PCM Excalibur 330 428 hours on it. I was pulling a tube on July 4th and the motor acted like it was running out of fuel and cut off and would not crank back only spit back through the intake. When it was acting like it was running out of fuel oil pressure was normal, temp was around 165 everything was within rang and did not give any warning lights what so ever. To top off my day it was pulled back to the ramp by a ski ray...... But his boat was running so.. Took it to the shop they have checked all the fuses non blown kill switch was good relays where also checking good, hooked to computer and it's not showing any codes. So with that its spinning over and trying to crank but will kick back through the intake like its out of time. They have checked the timing and its spot on changed cam shaft sensor didn't change a thing they where certain that was the problem but it wasn't boat has in range fuel pressure on the rails spark and oil pressure builds while spinning. It's like everything is trying to work just in the wrong order I personally pulled a plug and I felt it was dry for as much as it had spun over nor did I feel like I felt a pulse from the injector while I was holding a screwdriver on it so I guess my ? Is the ECM a very expensive part to just replace not to know if that will fix the issue or not and this boat place is telling me hey that's about all we know to try now. I know there are places to pull and they can test and repair the ECM's but still it's been down a month im ready to be burning up some high test again can someone please help point me in a better direction or give any ideas other than just swiping parts now because a computer is to showing anything wrong
thanks in advance
thanks in advance
