fuel gauge bad reading
  • dompate
    • Aug 2016
    • 23
    • Montreal Canada
    • 2010 SANTE 210 2008 SANTE 210 2006 SANTE 210 2006 MOOMBA V
    Hello, i own a 210 2010 with the central screen dash display, the fuel gauge never show the real level , always go up and down. I change the fuel sending units and its still the same !! did someone know what could be the problem ?? bad wire ? ECM ?
    Thank
  • kmarine
    • Jun 2017
    • 109
    • chicago
    • boss gt40
    Most likely a bad connector on back of fuel gauge or sending unit. Did you clean the wire connector when replacing the sending unit. after getting things working again a little shot of spray paint can be used to seal out moisture.
    • dompate
      • Aug 2016
      • 23
      • Montreal Canada
      no i dont , the connector looks good but i will double check ! thank
