Connecting a pebble watch to a nautique
  • Klipper
    • Jun 2018
    • 37
    • Muskoka, Ontario, Canada
    • 2018 SAN 230
    #31
    Sure, but only if your phone is connected to the stereo via Bluetooth or USB. It will not work if you're using an AUX cable.
    -Charles
    Mine has always been connected to Bluetooth and I have two different Pebble Classics, neither of them work with the "next track" function by long pressing the "volume +" button. Anybody else have this issue?
    • Lutfalah
      • Aug 2019
      • 5
      • Mexico
      • gs22
      #32
      Originally posted by NautiqueJeff View Post
      First, be sure you have the Surf Select option on your boat. If you do not, you will not be able to pair the Pebble Watch.
      If you do, you will need to pair the watch to the LINC system. Be sure to unpair it from your phone first.
      See these guides for more information.
      http://www.planetnautique.com/Correc...ringPebble.pdf
      http://www.planetnautique.com/Correc...tInterface.pdf
      Also, if your Pebble Watch is running an OS newer than 2.9.1, you will need to downgrade the OS before Surf Select will work. See this guide for more information.
      http://www.planetnautique.com/Correc...eDowngrade.pdf
      Hi i have a pebble 2 which firmware do i choose to downgrade ?
      • charlesml3
        • Jan 2008
        • 2487
        • Lake Gaston, NC
        • 2022 G23
        #33
        You can't. The Pebble 2 WILL NOT WORK with any version of Surf Select. Again, the supported models are:
        - Classic
        - Steel
        - Time
        - Time Steel
        No other models will work.
        -Charles
        • Lutfalah
          • Aug 2019
          • 5
          • Mexico
          • gs22
          #34
          I bought the classic. In the first wear, wtar got in and got messed up. I bought a steel which i had to return cause didnt work. Which would be the best? I just want to use it behind the boat all the time.
          Thank you
          • charlesml3
            • Jan 2008
            • 2487
            • Lake Gaston, NC
            • 2022 G23
            #35
            Thank you
            I just buy the Classic. They're the cheapest ones and the only difference is the Steel supports Ballast Shift which I never use.
            -Charles
            • kdonzi123
              • Nov 2012
              • 88
              • Lake Hopatcong
              • 2018 230
              #36
              Yes can only pause the music , i can not change tracks as well. Not a real big deal.Wondering though can you have multiple watches linked at the same time?
              • Lutfalah
                • Aug 2019
                • 5
                • Mexico
                • gs22
                #37
                Thank you. It is terrible that water gets in them when they are supposed to be water proof
                • Rbt
                  • Feb 2019
                  • 24
                  • Utah
                  • 2018 G23
                  #38
                  Same with mine. I can’t change tracks with my watch. Very frustrating because that and volume are the main things I wanted the watch to do
                  • charlesml3
                    • Jan 2008
                    • 2487
                    • Lake Gaston, NC
                    • 2022 G23
                    #39
                    No. It's Bluetooth. Only one device at a time can be in control of the LINC.
                    • Klipper
                      • Jun 2018
                      • 37
                      • 2018 SAN 230
                      #40
                      Originally posted by Rbt View Post
                      Same with mine. I can�t change tracks with my watch. Very frustrating because that and volume are the main things I wanted the watch to do
                      Is anybody else able to change tracks with the watch?
                      Sent from my Pixel 3 XL using Tapatalk
                      • charlesml3
                        • Jan 2008
                        • 2487
                        • Lake Gaston, NC
                        • 2022 G23
                        #41
                        I'll test it again this weekend. I don't use the track advance feature very often but it worked the last time maybe a year ago.
                        -Charles
                        • GMLIII
                          • May 2013
                          • 2821
                          #42
                          Yes I use the track changing feature all the time on the watch while surfing. As Charles stated above, this feature only works if the music is coming through a bluetooth signal. The feature will not work if the music is coming through an Aux cable.
                          • Klipper
                            • Jun 2018
                            • 37
                            • 2018 SAN 230
                            #43
                            Bluetooth does not work for me. Never has. I tried a few different classics and none of them work.
                            • charlesml3
                              • Jan 2008
                              • 2487
                              • Lake Gaston, NC
                              • 2022 G23
                              #44
                              OK, let's be clear on what we're talking about here. The Pebble watch communicates with the LINC via Bluetooth. That's the only way to connect the two.
                              Your phone connects to the HEADUNIT via Bluetooth, USB or AUX cable. Even if you go through the LINC to pair your phone with the boat, your phone is NOT paired with the LINC. It's paired to the headunit. The LINC simply acts as a remote for the headunit.
                              If everything is paired up and connected, pressing the volume button on the Pebble sends that command to the LINC which then forwards it on to the headunit. It's no different than pressing the button on the LINC itself.
                              -Charles
                              • Klipper
                                • Jun 2018
                                • 37
                                • 2018 SAN 230
                                #45
                                -Charles
                                I understand. My phone is connected to the HU via Bluetooth, and the pebble is connected to the Linc via Bluetooth. All other radio commands work on the pebble with the exception of next track.
