220 hard tank replacement to bag?
  • aaronmt
    • Jan 2016
    • 53
    • Washington
    • 2006 SAN 220 TEAM
    I am wanting to get rid of the hard tanks.I had a piggy back 750lb in our port locker however it hits our breaker panel when 2/3 full.We have decide to go with bags instead of the hard tanks.Does anyone have pictures of this?Are you able to use the carpet on top still and how big can I go?
  • swatguy
    • 1669
    • Midwest/ Northern IL
    • 2008 SANTE 210
    You wont be able to use the carpet fillertbat currently sits on top of the bag. You can get 1100's back there to fill completely.
    • aaronmt
      • Jan 2016
      • 53
      • Washington
      • 2006 SAN 220 TEAM
      Would you happen to have any pics.Any tricks to removing these hard tanks,im about to cut the things apart to remove them easier.
      • aaronmt
        • Jan 2016
        • 53
        • Washington
        • 2006 SAN 220 TEAM
        After doing some measuring I think ill be going with the 750lb bags.The 50"L x 20"w x 20"h seem to be the best fit for the room I have.This size should be able to fill completely with less interference with the engine dividers.
        • swatguy
          • 1669
          • 2008 SANTE 210
          My 08 210 allows 1100's to fill completely. The 220 should easily allow 1100's. if you search my screen name
          i did a step by step on how to remove the tanks .
          Basically you remove 8 screws that ancor the tank in to the floor. Remove the hoses. Then twist as you lift up
          • distinguishedmotorsports
            • Aug 2016
            • 489
            • Austin, TX
            yeah just like above said. lag bolts, 1/2 nuts on top. two per mount, at least two mounting tabs each ballast.
