I wanted to ask if any of you have your drain and fill fitting to the top of your 750's? I have twice now had the quick connect fitting pull out of the front of my 750 because of pressure from the bag shifting. Which can cause a little stress when you're back there on a rope and realize... huh... the bilge pumps running. I believe there will be no issues with a plug staying in on the front of the bag, I just don't know if it the bag will drain with the fitting on the top.
I use a 750 in each locker with the fittings to the top, never had an issue.2011 SANTE 210 ZR409 (6.0L)
I lengthened the hoses. The drain hose was at the bottom rear and the fill and vent hoses were on top. We had 1100's tho.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Ian S
