Aerator Fill Pump not pumping
  • homer12
    • Feb 2016
    • 584
    • Indianapolis, IN
    • 2004 SV211 TE
    I just replaced this fill pump on my belly tank. The remote valve is open and the manual valve is open. The pump is spinning hard, I can feel the vibration. It is brand new. It won't fill the tank though. Is it possible I got the polarity reversed on the wires and the pump is spinning backwards? I can't think of anything else wrong....
  • XBIGPUN66
    • Oct 2012
    • 479
    • Lake Mendota
    • WI
    Did you prime it by driving slow?
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
    2014 SANTE Reef Blue/ Black metal flake. NSS. Pro balllast. Boatmate trailer
    2004 SANTE Masters Blue. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
    2009 Moomba Outback Red(prev). Boatmate trailer
    • MikeC
      • Apr 2007
      • 535
      • Georgia
      • 1999 Ski Nautique (Python powered) 2017 GS22 (sold) 2005 SV211 (sold)
      There is always a possibility of getting it wired backwards if you had to wire the plug yourself. But most likely it's because the aerator pumps have to be primed, drive forward and backwards to help prime it.
      • homer12
        • Feb 2016
        • 584
        • Indianapolis, IN
        • 2004 SV211 TE
        Yes. I've definitely driven around to prime it and it seems the only thing filling the tank is the force of water going in there when the remote valve is open.
        • homer12
          • Feb 2016
          • 584
          • Indianapolis, IN
          • 2004 SV211 TE
          Looks like it is priming issue even though I've idled the boat around trying to fill. Pulled the pump, checked wiring and checked valves and obstructions and all seems good other than it takes forever and doesn't even get full
