I can't drain the ballast system in my Pro Air other than removing the intake hose and let it drain in the bilge which of course is a bit tedious.
Where is that drain pump located?
(the fill pump is next to the engine in the front)
Also the small LED light doesn't work on the starboard panel on the ballast drain switch. Are these panels know to break?
I need to find out if it is a faulty drain pump or a broken panel.
I've replaced the fill pump last season and it works ok now.
btw I got the vent system which lets air go in our out of the tanks while filling.
