2001 196 GT 40 100 amp alternator upgrade pulley doesn't line up
  • jgray
    • Mar 2016
    • 6
    • Squamish BC Canada
    • 2001 Nautique 196
    Just received my 100 amp alternator upgrade kit, it didn't come with any instructions. I figured out the wiring just fine but I can't get the pulley to line up. I tried the spacer that it came with but it sits out to far, without the spacer the pulley rubs on the alternator and sits in to far. I was just wondering if anyone else has run into this problem, if so what is the fix. Thanks Justin
  • t.franscioni
    • Jun 2014
    • 715
    • United States
    • 2002 SANTE
    Yes I had same problem. I went to my local hardware store and purchased another spacer and some washers and played with different arrangements until I got it perfect.
    • t.franscioni
      • Jun 2014
      • 715
      • United States
      • 2002 SANTE
      You can pull your spacer off your original alternator as well and try that. I reused the original alternator pulley also I recall.
      • jgray
        • Mar 2016
        • 6
        • 2001 Nautique 196
        So I ended up buying some thin washers and stacking them until it was aligned, Thanks for your suggestions
