Been having an intermittent starting issue on our new to us 2006 SAN 210. 3 times this year it has happened. First 2 times it happened we were using the boat and after shutting the boat off to swim a little it wouldn't start. Turns over great, just won't fire. No missfire or partial fire either. Like a loose ground or something. We were able to get it to start by cycling the batteries and key/pad a few times. This weekend no luck, wouldn't fire after doing that. Looking for suggestions of what to check or if anyone knows what pins in the harness to check for continuity or 12V.
Thinking this boat may have been a salt water boat.Having similar issues on the ballast pumps but can get those to work by wiggling the harness in the port locker. Engine is the 330 PCM of course.
Thanks for the help.
