I got my IACV from Amazon for $50, looks like they are $45 now. Here is a link.
The other common cause of the problem are the ECM or Starter replays,you could try replacing these too as they are only about $15.
I think when you are having the issue you can try disconnect the IACV and see if the looping goes away.
I have a mild version of this (my RPMs only fluctuate about 250 RPM) it can get bad at times and my boat has cut out a couple times. I replace the IACV and the ECM replay and nothing changed.
