Port side bolt either fell out or broke off. Tower is now loose. Noticed laying on the floor under the seat with the plate and washer. I'm to big to get up underneath there. Can someone tell me if its broken off or if you just need someone small to reach up underneath and reattach and tighten?
when you say loose, can you move the tower up and down or side to side as well? Could be either a nut that loosened up and fell off or a bolt or 'all' thread bolt that loosened and fell off so there should be another piece or 2 laying on the floor someplace..
Yes it was the bolt, nut (still on the bolt as it is a locking nut), washer, and the plate (which is a steel piece about 1/4" thick and 2" wide by 4" long. My question is does it screw back in or did it break (snap) off and we would need to replace the bottom bracket?
