My boat takes on a ton of water when at the lake and don't understand why. AfterI fill up fat sacs (750lbs) in side compartments and stock belly I usually keep the switch on open so while the boat is moving it will continue to fill. I can pull engine hatch and look in and not see any water. Then when I pull boat out of water I always pull drain on ramp bc my boat sits with the bow down on the trailer. Here is when gallons of water come pouring out.
It's like there are two compartments for water because under middle bow seat there is a little drain and there is usually water on the carpet there which is a pain in the butt bc I have to pull the wet/dry vac out when I get it home.
Anyone else with this boat have a ton of water in it when drained. Any ideas on what I can do. I guess first I should check the bilge by the belly tank and make sure it's working but still can't figure out where the water is coming in from. Belly tanks???
