Waxing
  • dixxy
    • Apr 2015
    • 137
    • canada
    • 2019 GS22, previous boat 2005 SV211
    It's a bit hard to see. .but the racking that is under the boat is the left over from the actual taking used if the front and back...
    Look at the top left of the picture you see an orange bar going across. .there is 2 cross pieces 7"wide hooked on the legs that run to the ground. ..same thing in the front. .then spanning on top of those across is 2 more pieces. ..both chain blocks are attached on those pieces. ..
    I had to cut the legs has they were to high for my garage. ..so I got more cross members and used them to place under. ..
    Now the weight is spread between the hooks and the'stands'under. ..
    Real easy to work under the boat now. ..
    Plus I am using this setup to get my trailer repainted. .
    Sent from my SM-G900W8 using PLANETNAUTIQUE mobile app
