Checking my bearing buddies?
  • NautiqueGirl33
    • Jul 2015
    • 56
    • North Augusta Sc
    • 2007 Super Air Nautique TE
    trying to service my trailer :
    a trailer shop wanted 300 bucks to repack these.. If they are maintained they shouldn't need repacking correct??
    I pressed on the piston ring 3 out of 4 seem to move back and forth a tiny bit.
    Should I add a few pumps in each and call it a day?
    from what I have read in here seems they do not need repacking unless failure .. Thank u in advance ..
  • Evening Shade
    • Apr 2015
    • 1295
    I think you can just add a few pumps of grease and you will be fine. I can't imagine paying $300 for a trailer shop to do that. Thats why they have grease fittings...to make greasing the bearings easy.
    • shag
      • 2217
      How old is the trailer? How often does it get dunked? How many miles? I would have them re-packed after 3 years at least, with moderate use... Just my .02
      • NautiqueGirl33
        • Jul 2015
        • 56
        • North Augusta Sc
        my second summer with it.. get dunked 3x a week..Boat is 07 it's an upgraded trailer from what it came with need to check year..appreciate it love this forum!!!!
        • ski4evr
          • May 2010
          • 613
          • Bowling Green, KY
          • 2005 SV 211
          3. With Bearing Buddy® installed, how often do I need to repack my bearings?
          We don't recommend inspecting your bearings more frequently than once every 5 years, provided you properly maintain the grease level in the hubs, and your bearings and seals are in new condition when you install genuine Bearing Buddy®. The Bearing Buddy® system maintains a constant pressure of 3 p.s.i. on the grease inside the hub. Since the hub is always full of grease (with proper maintenance) there is no need to repack your bearings. Some customers have reported that their Bearing Buddy® units were removed for the first time after 10 to 15 years of use, and the bearings still looked like new.
          This is straight from bearing buddy's site. If they still have grease In them, they recommend filling back up and checking in another 2 years. Just don't let them get empty. I usually jack up each wheel and give it a wobble test to make sure the bearings haven't developed any play and roll on.
          2005 SV-211
          • kend
            • Oct 2013
            • 193
            • DFW, Texas
            • current 2001 Air Nautique previous 1988 Sanger DX
            Originally posted by ski4evr View Post
            [B]Just don't let them get empty. [/LEFT]
            ^^This Once they get empty water can get in and rust can start so keep them full. There are "waterproof" types of grease that will last longer.
            Ken
            2001 DD Air GT40
            • seth
              • Jun 2008
              • 549
              • Santa Barbara, CA
              • 01 SAN-sold
              Pump grease in until you see the black seal just start to push out against the spring. They are then full.
              • NautiqueGirl33
                • Jul 2015
                • 56
                • North Augusta Sc
                10/4.... mine does not have the blue insert to show current level.. How do I know how much is good enough??
                I'm going to change a few tires on trailer will inspect and just add grease this season...
                appreciate all the help.
                • NautiqueGirl33
                  • Jul 2015
                  • 56
                  • North Augusta Sc
                  Seth.. just saw your message !! thank you!
                  • jtryon
                    • Jun 2011
                    • 239
                    • CT
                    • 2007 Centurion Typhoon
                    Exactly this ^ I have a 1988 trailer and boat and tow a lot in the summer, with a couple long trips during the season and haven't had to touch mine because I keep them greased. I give each bearing a few pumps of grease every few weeks and am good to go.
