NSS failure
  • XBIGPUN66
    • Oct 2012
    • 479
    • Lake Mendota
    • WI
    We had a problem like this and it turned out to be the actuator.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
    2014 SANTE Reef Blue/ Black metal flake. NSS. Pro balllast. Boatmate trailer
    2004 SANTE Masters Blue. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
    2009 Moomba Outback Red(prev). Boatmate trailer
    • c640947
      • Jul 2013
      • 112
      • Badin Lake, NC
      • 2021 Nautique G23 Paragon ///// 2016 Mastercraft ProStar with tower
      Just sold my 2014 G to my cousin and he's having problems with the NSS. It makes an awful sound but it does deploy, sometimes it throws a circuit fault. Assume the actuator needs to be replaced (since there was nothing stuck between the plate and the hull)? 725 hours on the boat.
      So if that's right, its relatively easy to get one but our question comes on the "how" to replace it. Things seems straightforward from the outside but how do you get access to the wire on the inside of the hull and how is it fed through? Will we also need a special sealant? Anyone have pics? Didn't see the wire in the subfloor ballast access hatch so assume access is gained somewhere in the engine compartment?
      Thanks in advance for your help.
      Andrew
      Current:
      2016 Mastercraft Prostar with tower
      Previous:
      2014 Super Air Nautique G23 XR550 / EZ Loader trailer with custom Electric over Hydraulic brakes
      1996 Sylvan Special Edition 24" pontoon boat
      2006 Mastercraft X2
      1995 Mastercraft ProStar 190 with new dimension tower
      • Ditch
        • Sep 2017
        • 32
        • Hendersonville, TN
        • 2013 G23 450
        Any luck with this? Mine failed yesterday with the same symptoms and is very slightly deployed.
        Thank you
        • c640947
          • Jul 2013
          • 112
          • Badin Lake, NC
          Had to replace the actuator. I think it is just take off the plate on the back of the boat and replace it. $400
          https://www.nautiqueparts.com/product/nss-actuator/
          Current:
          Previous:
          2006 Mastercraft X2
