Oil guys I need help!
  • Fgroce
    • Dec 2016
    • 179
    • Middle Georgia
    • 2002 Ski Nautique
    No I would not recommend that oil it must meet the SM specification according the manual that I looked at. I would run a 15-40 oil that meets the
    SM specification. Hope this helps. The 5.3 engine does not have a flat tappet camshaft so the modern oils are what is called for. Unlike running modern oils in a older engine with a flat tappet cam shaft. Running the modern oils in the older engines may shorten the life of the cam shaft.
    • wakemaker
      • Aug 2010
      • 237
      what about this ??
      http://www.shell-livedocs.com/data/p...0d7017f8b7.pdf
      • 2001SAN
        • Apr 2012
        • 203
        • Ireland
        • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
        Originally posted by thekneeboardking View Post
        Hi there,
        I am from the UK and when I've looked for the oil grades for sale here the grades your talking about seem to relate to motorbikes is this correct?
        https://www.ebay.co.uk/itm/112347977974
        The valvoline vr1 doesn't seem to be available in this country, any help please.
        Regards
        David
        Hi David,
        I'm in N.Ireland and source VR1 20-50 from flea bay:
        http://www.ebay.co.uk/itm/VALVOLINE-...UAAOSw241Yktne
        Not sure that is you need it for your roller cam engine though.
        D.
        • vanhanbr
          • Mar 2014
          • 223
          • Wisconsin
          • 2008 SAN 210
          The OP stated he has the EX330 engine, not the GT40. He doesn't have flat tappet cams and does not need a high zinc oil. Shell Rotella T6 5-40 would be a good choice and is readily available. I would just run the conventional Rotella T 15-40 and keep up with the oil changes.
          2008 SAN 210
          1997 Sport Nautique
          • JD ski
            • Feb 2017
            • 101
            • Mountains North of Tahoe
            • 1999 Air Nautique, GT-40 Pro-Boss 1975 Century Re
            I did not look at your year specific motor requirements. I am going to go with your owners manual recommends 40w non synthetic. If that is what it recommends that is what you need to run. As already suggested you need a high zink content oil. Valvoline VR-1 makes a high zink content oil in standard and synthetic. These oils are not typically available at general parts stores. You may need to go to a shop that has high performances interest or have a generic shop order the oil you want. I run Moble-1 in all of my modern vehicles. My boat gets Valvoline VR-1 40w not synthetic as recommended. What you want to run and what your boat motor needs may not be the same.
            If your motor has been running standard oil it is best to stick with that. Oil has different weights as most are aware. Oil weights cause different wear patterns such as sand paper has different wear patterns. Also bearing gaps need a specific weight oil to fill the gap (oil pressure) This is designed into the motor. In a used motor switching to a synthetic and specifically of a lower viscosity will lower your oil pressure. This could also be a problem as the motor is designed to run with a specific amount of oil pressure. For these reasons my GT-40 runs Valvoline VR-1 and it is hard to find, I order it.
            • vanhanbr
              • Mar 2014
              • 223
              • Wisconsin
              • 2008 SAN 210
              #21
              I ran straight 40wt VR-1 in my old boat with the GT40. It is available on Amazon.
              But I am certain the EX330 has roller rocker cams and does not have the Zinc requirement.
              2008 SAN 210
              1997 Sport Nautique
              • rossrips7
                • Feb 2010
                • 233
                #22
                Only one cam in our boats fellas
                • Fgroce
                  • Dec 2016
                  • 179
                  • Middle Georgia
                  • 2002 Ski Nautique
                  #23
                  The oil you are looking for needs to have a SM API rating. You can run a synthetic 10-40 or 15-50 it will not matter. I run Amsoil in all my engines and will continue to do so. I do not agree with PCM's recommendation for not running synthetic. You let a boat sit for days or weeks on end the put it in the water and run the HLLL out of it. Oil is cheap buy the best you can., Enjoy your boat. You do not have to run a diesel oil in your motor because it does not have a flat tappet camshaft.
                  • lucky7t
                    • Mar 2011
                    • 1306
                    • Oklahoma
                    • 2015 SANTE
                    #24
                    I use rotella but if your stuck on synthetic I would go amsoil
                    Current Correct Craft Boat
                    Correct Craft Boats Owned
                    • thekneeboardking
                      • Sep 2016
                      • 9
                      • Manchester / United Kingdom
                      • 2007 196 Limited 330 excaliber With Tower
                      #25
                      Originally posted by 2001SAN
                      Hi David,
                      D.
                      Thanks for your help, just bought some now
                      Regards
                      David
                      • DocPhil
                        • Jan 2016
                        • 480
                        • Midwest
                        • 2016 G23; yamaha superjet
                        #26
                        !5w-40 Delo or Rotella. Good, cheap oil
                        • blakeyates
                          • Jun 2015
                          • 21
                          • Griffin, GA
                          • 2019 Ski Nautique H6, 6.2 - 450 HP
                          #27
                          For a different twist in advanced engine oil protection, go to www.LElubricants.com and look at 8700 or 8800 Monolec Engine Oil, 15W-40. This has the most wear protection and robust additive pkg of any engine oil; not available for retail as it's an industrial "heavy duty" product designed for end-users.
                          • Fgroce
                            • Dec 2016
                            • 179
                            • Middle Georgia
                            • 2002 Ski Nautique
                            #28
                            For what these boat cost and how hard we run the engines, I would recommend Amsoil. They have a good warranty. I have been running it for over 25 years.
