2005 SANTE Starboard tank leak
  • tommer12
    • 110
    • Fort Mill, SC
    • 2006 Ski Nautique 206 2005 Super Air 210 Team 1992 SNOB 1984 Ski Nautique
    Is there a trick to have it stop a slow inlet leak from happening? I have the valves closed, the pump off, but i still get water in the tank when running fast. Its not a huge deal, just have to pump water back out of the tank. Be nice not having to do this all the time. Its not a fast fill, but slow. Thanks!
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    Is this the valves at the helm or the actual brass water intake/shutoffs? If it is the helm valves, I thought that was a common complaint on those years (2000-2006?) I don't know when they replaced the flowrite valves, but they were initially supposed to be remote valves for livewells, not probably the forces we put on them.
    • tommer12
      • 110
      • Fort Mill, SC
      If I knew where it was leaking from Id probably have it figured out.
      • Nick Heimer
        • Apr 2015
        • 82
        • Omaha, NE
        • 2005 SANTE 210
        I have the same problem. Both both valves shut and I still get some fill when riding fast.
        • tommer12
          • 110
          • Fort Mill, SC
          Yup, I just have one tank/valve acting up. Bought the boat with 270 hours on it last year and inherited this problem. Been dealing with it ever since. Figured it was time to fix it.
          • swatguy
            • 1668
            • Midwest/ Northern IL
            • 2008 SANTE 210
            It's pretty common problem. Its most likely the flow rite valve. I believe it's the V1 that is the direct replacement. Just order new one and swap the old one out. Not sure exactly where it's in line in your system but it's a red and black looking box
            https://flow-rite.com/products/marine/valves
            • tommer12
              • 110
              • Fort Mill, SC
              assuming this post? http://www.planetnautique.com/vb5/fo...ballast-valves
              • tommer12
                • 110
                • Fort Mill, SC
                This is the replacement then? http://www.nautiqueparts.com/helmbal...trolvalve.aspx
                • swatguy
                  • 1668
                  • 2008 SANTE 210
                  good find never knew they replaced those with different mfg. Those would be it. If it were me I would just do them all at one time.
