2007 196 Model, Fuel Pump
Situation; when the ignition key is turned on, the fuel pump does not turn on. Fuses are intact. Not sure if the fuel pump relay fuse (sealed 5 pin) is faulty. Question; I will check with a tester to see if the fuel pump wire sees power. If it does have power am I to assume the fuel pump has failed and requires replacement? Alternatively, if there is no power, the I assume the relay is faulty and requires replacement (would Napa have this relay switch?). Please confirm if there is anything else I should check. Also, have you heard is ethanol blended gasoline are the culprit to failing pumps?
