Draining coolant from a closed loop 6.0
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Did a search and didn't find anything.
    What is the easiest way to drain the antifreeze (dexcool orange) from a ZR closed cooling system? I'd like to switch coolants, heard nothing good about Dexcool, so I'd like to get it all out.
    TIA
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
  • john_keck
    • Jun 2010
    • 51
    • NC
    • 2006 220 SANTE
    Hmmmm, not sure about the easiest way - I had to pull the starter off to get to the lower drain point on my 2006 ZR6. It was doable but difficult given the amount of space.
    • agarabaghi
      • Aug 2013
      • 31
      • Maitland, FL
      PCM manual has instruction on how to drain a zr450 does that help?
      • j2nh
        • Dec 2003
        • 628
        I will check the PCM manual and see where that leads.
        Thanks john_keck and agarabaghi. Here's hoping I don't have to pull the starter.
        2018 200 Team H6
        1987 ProStar 190
        • jkallen21
          • Jan 2013
          • 403
          • United States
          • 2006 Super Air 220
          FWIW - I have a closed loop 2006 ZR6 and have never had a cooling issue.
          • j2nh
            • Dec 2003
            • 628
            Neither have I but new coolant after 5 years is good preventive maintenance. I would like to switch from DexCool as I have not heard good things about it.
            2018 200 Team H6
            1987 ProStar 190
            • d_nodixon
              • Sep 2008
              • 475
              • Hammond, LA
              • 2013 SAN 230
              What bad things have you heard? Changed mine a while back, bout to change it again. Don't recall the steps, but it was not hard to do. The pcm manual was my guide. Be sure to check the anode and inspect the heat exchanger.
              2013 SAN 230
              2006 SSN 210 (SOLD)
              • j2nh
                • Dec 2003
                • 628
                From a 2008 class action lawsuit:
                "The lawsuits were filed on behalf of owners of General Motors vehicles, which were factory-filled with "Dex-Cool" coolant. In summary, the lawsuits alleged that Dex-Cool degraded certain vehicles’ intake manifold gaskets and other engine sealability components, and that in certain other vehicles, Dex-Cool formed a rusty sludge, clogging the vehicles’ cooling systems and causing vehicles to overheat."
                2018 200 Team H6
                1987 ProStar 190
                • ericchile
                  • 283
                  • Utah!
                  • 2009 SANTE 230
                  I posted the same question last year when I changed mine.
                  http://www.planetnautique.com/vb5/fo.../27843-dexcool
                  After some research I believe I remember figuring out that two things have occurred. The dexcool in it's original formula had problems with the head gaskets that GM was putting in their motors.
                  1) I believe the formula has changed after determining the problem.
                  2) Also PCM said that their head gaskets are not affected. That is was combination of the original dexcool and certain head gaskets.
                  It has been a while but I used this brand
                  http://www.amazon.com/Zerex-ZXEL1-DE...ywords=dexcool
                  My Nautique dealer said they are using dexcool still as well. Please confirm everything though!
                  • jhersey29
                    • Nov 2013
                    • 330
                    • Colorado
                    From PCM website on the FAQ page : "For Model Year 2020 and newer, use Propelene Glycol (green in color). For previous years use DEX-COOL (pink/orange in color). I have ordered a new ZR409 to replace my GT40 and get ZO, etc. I imagine the engine will show up without AntiFreeze but not sure. Since it's a new motor would it be a 2021 or does it fall under the older motors since the 6.0 is actually an older engine? Does seem like green is the safest way to go.
                    • ESP
                      • Feb 2021
                      • 25
                      • Regina Saskatchewan Cananda
                      • 2020 GS22
                      Easiest way to change with out making a mess get 6 ft 5/8 heater hose run the hose through the drain under the boat, pinch the heater line from the motor turn off the tap remove hose, install heater hose run through the floor have someone manage the tap run into antifreeze containers, zero mess.
                      2020’s run poly propylene glycol it is green yellow and if you have leaks goes neon under black light.
