Originally posted by RCHANDED
1 Brake fluid (obviously)
2 Caliper grease for the bolts the brake calipers need to slide on - available at any auto parts store (you can't use the same marine grease for the bubs)
3 New cotter pins or tab washers that work with the nut to hold the hub on the axle. (doesn't list it in the kit)
4 Replacement wiring harness.
One aspect I like better about the kodiak disk brakes are that they come with ceramic pads (no brake dust to get all over the wheels) - you could probably get ceramic pads next time when you need to replace them in years to come.
