2002 SAN
  • ski4evr
    • May 2010
    • 613
    • Bowling Green, KY
    • 2005 SV 211
    When you say steering is smooth, can you rotate it freely with your little finger? I went through the same thing. A good cable allows one finger drivng even under power. A bad one creates all kind of weird feelings including feeling hard to turn one direction. Fought it mentally for a whole season then replaced it. Totally worth the amount of work.
    2005 SV-211
    • hpdixon3
      • Dec 2014
      • 44
      • USA
      yea, when the boat is on the trailer I can steer super easy, pretty much with one finger. But, when the boats is under way I almost need two hands on the right hand turns. Left turns are pretty smooth.
      • hpdixon3
        • Dec 2014
        • 44
        • USA
        Is this the part you had replaced? http://www.nautiqueparts.com/steerin...1998tonow.aspx
        • swatguy
          • 1666
          • Midwest/ Northern IL
          • 2008 SANTE 210
          sounds like a steering cable issue. While you're replacing that, drop the rudder and grease that bad boy too
          • hpdixon3
            • Dec 2014
            • 44
            • USA
            right on. thanks for the help
            • ohiowake2
              • Jun 2014
              • 106
              • OHIO
              • 2001 SAN
              #21
              My 2001 SAN turns a little hard to the right but not bad, is that the cable or is that because of the way the prop spins the water?
              • swatguy
                • 1666
                • 2008 SANTE 210
                #22
                In that particular year you will always find a little more resistance turning to the right than the left. As you mentioned, due to the prop wash. However if it becomes a two handed muscling to get the wheel going it's time for a cable and a greasing of the rudder.
                • cjohnsen1611
                  • Jun 2013
                  • 22
                  • discovery bay
                  #23
                  I had this same problem with my 2003 SAN. I ended up replacing the rudder mount. Bought one from nautique parts which came with the grease fitting. I cleaned the rudder shaft and applied new grease. Boat turns great now.
