Jabsco ballast puppy plumbing/fitting
  • wviveen
    • Dec 2004
    • 143
    • Santa Monica
    • 2016 Nautique G23
    This winter I purchased 2 ballast puppy's for building my ballast system. I am now gathering all the parts i need for the system.
    But since I live in the Netherlands I have a really hard time finding the fittings that go into the head of the pump to connect the hose to.
    Since the thread in the head of the pump is NTP it is impossible to find the correct fittings for it as NTP is not supported in the Netherlands.
    Even the company that sold me the pumps is not able to arrange these parts for me, their advice was to just attach the hose with a hoseclamp.
    I am looking for the following fitting : Pipe - 1/2" NPT - Hose ID 3/4" Straight
    Does anybody know where I can find these online and have them shipped to me for a reasonable price ? I tried westmarine.com but for an order of 25 $ they charge 35 $ shipping costs.
  • sperbet
    • Aug 2004
    • 284
    • Truckee, CA
    RE: Jabsco ballast puppy plumbing/fitting
    You should just buy tubing that fits over the fitting on the pump and use a standard hose clamp. That fitting you have pictured will restrict the waterflow and make your pumps operate slower. It's quicker and easier to just use bigger tubing and clamp it. I have three jabsco's set up this way, no leaks, no problems.
    Ummm, I\'ll take the REAL 210 please. Thanks.
    • wake_fun
      • 1330
      • CA
      • 1995 Super Sport
      http://www.mcmaster.com/
      Photo Album
      Ballast Install 1
      Ballast Install 2
      Amp Install
      PPass Install
      Alternator Install
      • wviveen
        • Dec 2004
        • 143
        • Santa Monica
        • 2016 Nautique G23
        would these fittings restrict flow that much ??
        But then you would have to use 1' tubing. I have ordered the new fly high sacks and I dont know the size of the fittings on those ? (v drive set).
        that would then also be have to be 1", correct ? Otherwise it would not matter if I use the fittings or not.
        Or am is my assumption not correct ?
        • sperbet
          • Aug 2004
          • 284
          • Truckee, CA
          Not sure about those exact sacs. The tubing for most sacs is standard and should be 1". The blue waterbed fittings are made for 1" tubing. Larger tubing equals less restriction, better water flow and less fill/unfill time.
          • gotpwr
            • Aug 2004
            • 244
            • Louisville, KY
            • None
            Fly high makes a 1" fitting for your sacks. Go to http://www.barefootinternational.com/fatsac.htm and scroll down to the bottom of the page. You need the W738 fitting.
            2000 Air Nautique Powered by FORD <-- Former Boat
            • MHayes
              • Aug 2004
              • 830
              • Roswell, GA
              Just stay consistent on the inside diameter and you should be fine
              2001 Air Nautique
              • wviveen
                • Dec 2004
                • 143
                • Santa Monica
                • 2016 Nautique G23
                Ok..thanks for all the advice. I will skip the fittings and just mount the hose directly on to the pumps. Then the inside diameter will be 1" from pump to sac.
                  • 2909
                  • Current 2017 GS22
                  These guys have all the fittings and good tubing too.
                  LINK
