Two things:
ON the power up of a wakeboarder, at about 12 knots, the boats slows about 3 knots and i have to add more power to attemp to keep a consistant power up, till it gets to the set speed. wish i knew how or what to do to eliminate this.
also, i have to hold or provide some additional pressure on the throttle as it will creep back down past the set point and then deactivate the PP. Is there a way to tighten the throttle so it wont creep. would that be in the sender unit of the throttle or on the carburator.
thanks
thanks
