Dash Pod on 2000 SAN
  • Byron
    • Jan 2014
    • 17
    • Raleigh, NC
    • 2014 210
    The dash pod on our 2000 SAN has pulled through all the thumb screw attachments. Is there a good method for fixing this problem to get the dash attached securely?
  • Chexi
    • May 2026
    • 2119
    • Austin
    • 2000 SAN
    Leather repair pros can fix the pod. Also, I use washers on the two lowest screws on either end.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • Byron
      • Jan 2014
      • 17
      • Raleigh, NC
      • 2014 210
      Thanks. Are you just using metal washers?
      • jhersey29
        • Nov 2013
        • 330
        • Colorado
        Ace has some nice black washers you can use for the top 2 holes. I picked up 2 1.25" steel black washers and matching rubber washers. Rubber went under the steal ones and held great. Since they are black you really don't notice them. You might also be able to do the same but smaller with the bottom 2. My 4 were all ripped out and I used Plexus, fiberglass, and a dremel to remold the holes at the bottom plus the washers at top with remolded area to increase the surface area. That was a challenge to say the least.
        • Chexi
          • May 2026
          • 2119
          • Austin
          • 2000 SAN
          http://www.planetnautique.com/vb3/sh...ash+pod+repair
          Check out this thread.
          Now
          2000 SAN
          Previously
          1999 Air Nautique
          1996 Tige Pre-2000
          • kylant
            • May 2010
            • 546
            • Lake Tahoe
            old thread, but I am in the same boat. Has anyone come across a good fix for this situation.
            thanks in advance
            • goldfisch
              • Apr 2015
              • 29
              • elkhart indiana
              • 2001 sante
              I used Velcro just for a temp. Fix Seems to be working pretty good
