Electrical help
  • kileyb
    • Oct 2010
    • 7
    • Keizer, OR
    • '92 Excel Bowrider
    Electrical help
    I have a 92 excel with the electric sun deck actuator. Opens fine, closes sometimes. I can jump from the hot side (blue wire). to the load side (orange wire with black wire) of the switch and make it work every time. The hot wire feeding the whole circuit tends to get HOT pretty quick especially when going up. Again sometimes it works ok then it will decide to stop. I've replaced the switch with similar results. I'm baffled. (Says the electrical novice).
